Da_RoCk Posted October 26, 2004 Share Posted October 26, 2004 Hi everyone, this is our office. The actual office is already finish, this will be used in the upcoming website. this is 2 days work. by the way, the glass wall as u may interpret it is actually a solid wall to have a clearer view of the layout. C&C are welcome... Thank you very much Link to comment Share on other sites More sharing options...
Da_RoCk Posted October 26, 2004 Author Share Posted October 26, 2004 here is a blow up of the view... Link to comment Share on other sites More sharing options...
Da_RoCk Posted October 26, 2004 Author Share Posted October 26, 2004 Hi martin... thanks for noticing... yep there is a problem. im still trying to figure out the proper way of presenting the transparent wall... my coleague suggest to use a falloff/gradient material with it to so that it would fade out and be solid at the bottom. im not sure with that solution cos of the inner and outer surface of the wall bothers will bother the material. Regards Link to comment Share on other sites More sharing options...
pmanahan Posted October 26, 2004 Share Posted October 26, 2004 The glass wall is confusing in both images. I would make it a solid wall but put it at 10% (or whatever looks good) opacity. In photoshop you can mask off the walls and then paint it more opaque in some areas where it is not important to see through the walls, in the corners or by the floor. pmanahan Link to comment Share on other sites More sharing options...
marckie258 Posted October 26, 2004 Share Posted October 26, 2004 Da_Rock nice rendering... i was in this office a few weeks ago. the ambient is so cool. there was a black maybe a curtain separating the workstation and the counter, but in this image i did not see it anymore. heheheheheheh... MARK MAC Studio Link to comment Share on other sites More sharing options...
Da_RoCk Posted October 26, 2004 Author Share Posted October 26, 2004 btw, im using vray @pmanahan: thnx for the suggestion. im trying to solve that as of the moment. But we wanted it to be clear, we tried a little transparency but it would just hide the door... using opacity wouldnt make the Gi wont in the interior if i use the opacity. @marckie: wen wer u here? was i here already? Yep there was a temporary counter separating the counter and the workstations. As you can remember it was broken and still until now, wasnt fixed. OT: where are the fruits? txt nya bai... d ta magabot sa chat room... Link to comment Share on other sites More sharing options...
voltaire_ira Posted October 27, 2004 Share Posted October 27, 2004 you forgot my laptop on the counter!!!you should have done that!harharhar! cool!nice render m8t! Link to comment Share on other sites More sharing options...
kicks Posted October 27, 2004 Share Posted October 27, 2004 Link to comment Share on other sites More sharing options...
pmanahan Posted October 28, 2004 Share Posted October 28, 2004 Attached is what I had in mind for photoshoped transparent walls. Link to comment Share on other sites More sharing options...
Da_RoCk Posted October 29, 2004 Author Share Posted October 29, 2004 @pmanahan: yp, thats wat i did. Thanks Link to comment Share on other sites More sharing options...
