Guest BmlLokesh Posted May 5, 2014 Share Posted May 5, 2014 . Hi all, How do I recreate above image through procedural maps I tried with marble procedural maps, it is not giving the random distribution of colors I tried even with masking (B/W image created in Photoshop) no luck I even tried with shellac and vray blend material no luck please suggest me how do I do this Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 5, 2014 Share Posted May 5, 2014 I don't think 3D Max procedural can handle that type of texture, maybe if you model the lines and apply a material per object, or material per element, can help you but that will involve modeling the lines. Personally I would create that texture in photoshop, can be faster and if changes come later, it will be easy to swap a texture than re model the whole thing. Link to comment Share on other sites More sharing options...
Tommy L Posted May 6, 2014 Share Posted May 6, 2014 Depends how many colors you want. You could use a gradient ramp with colors in the channels or you could use a gradient ramp in the mix channel of a mixmap then put noise maps (tiled to like .001 in the horizontal axis) in the colors. Link to comment Share on other sites More sharing options...
