jinhengyin Posted May 7, 2014 Share Posted May 7, 2014 the original link of this visualization: http://www.cgarchitect.com/2014/04/aatu-sanya-luoniushan-industrial-park-storage Making of LUONIUSHAN INDUSTRIAL PARK-STORAGE Original link of this visualization http://www.cgarchitect.com/2014/04/aatu-sanya-luoniushan-industrial-park-storage Hi, our company name is SHANZI Digital which is located in Tianjin, China. We would appreciate Jeff Mottle would give us this opportunity to show the process of our latest commissioned work for the listed company Luoniushan in Hainan, China. The architect is Yin Jinheng, who is from Tianjin University. The project is for a modern frozen storage which is part of the industrial park in Sanya. These screenshots will show our process of modeling and post-processing which are in 3dsmax with Vray, and Photoshop. GAMMA SETUP In common, we always start the work with Gamma 2.2 to ensure later renders will in a correct level of illumination, which will also help us add the least amount of lights in 3dsmax. MODELING Provided with the architect’s 3d files and the other reference images, we began to model the base building in 3dsmax with standard method. At this step, we always divide the building in layers by different materials. It will be easy for us to choose and adjust the parameters in later steps. View from the top. VEGETATION For the vegetation and environment I used a famous plug-in Multiscatter. Thanks to the Evermotion company’s product, we selected a kind of plant which is not so simple. Then we scatter these grasses in the limited area at the right corner of this viewport. Here are the multiscatter parameters. MATERIAL & TEXTURES With this special viewport we didn’t use many materials. Here you can check the detailed settings in the screenshots below. LIGHTING & ENVIRONMENT In our regular rendering process, we’d like to vray default environment map which is connected to the vray sun. To light up the interior of this storage, we use vraylight with the parameters in this screenshot. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted May 10, 2014 Share Posted May 10, 2014 Very mystic atmosphere! Nice work! http://www.cgarchitect.com/2014/02/aatu7sanya-luoniushan-competitionwinner2 Link to comment Share on other sites More sharing options...
