sonybutarbutar Posted May 7, 2014 Share Posted May 7, 2014 (edited) Hello guys, I've some serious problem. My name is Sony and I'm architecture student. This is the first time I used Vray for rendering my homework. maybe you guys can help me why my render results isn't good. I've try to fixed it but isn't work. Please tech me to make right setting for exterior render. So this is my render results. ew so bad! and i've try one more time and the scene are too bright ( the tutorial made me confused Edited May 7, 2014 by sonybutarbutar Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 7, 2014 Share Posted May 7, 2014 (edited) Student? good, read this and follow the tutorials. Edited May 7, 2014 by fco3d Link to comment Share on other sites More sharing options...
sonybutarbutar Posted May 7, 2014 Author Share Posted May 7, 2014 Hello. I can't see the tutorials anywhere. Would you to incude the link so I can learn from it. thank you Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 7, 2014 Share Posted May 7, 2014 Click this text for the links Link to comment Share on other sites More sharing options...
heni30 Posted May 7, 2014 Share Posted May 7, 2014 Hi, My name is Hitachi...............just kidding! Your light source, whether it be the sun or Vray lights, has an intensity control called "MULTIPLIER". Your value in that box is obviously too high. Start by cutting it in half and see what that does then keep adjusting up or down.......and read and do the tutorials. Link to comment Share on other sites More sharing options...
Tommy L Posted May 7, 2014 Share Posted May 7, 2014 I'd say you are using a Vray sun and not using the VRayCamera with exposure enabled. If that sounds like gobbledygook then follow the first poster's advice and read all the ChaosGroup tutorials. Link to comment Share on other sites More sharing options...
Ismael Posted May 7, 2014 Share Posted May 7, 2014 If that sounds like gobbledygook then follow the first poster's advice and read all the ChaosGroup tutorials. Agree. Link to comment Share on other sites More sharing options...
sonybutarbutar Posted May 8, 2014 Author Share Posted May 8, 2014 Ah I see! thank you so much Link to comment Share on other sites More sharing options...
sonybutarbutar Posted May 8, 2014 Author Share Posted May 8, 2014 I'd say you are using a Vray sun and not using the VRayCamera with exposure enabled. If that sounds like gobbledygook then follow the first poster's advice and read all the ChaosGroup tutorials. Sadly I would say yes. I think it would be the same Link to comment Share on other sites More sharing options...
sonybutarbutar Posted May 8, 2014 Author Share Posted May 8, 2014 Hi, My name is Hitachi...............just kidding! Your light source, whether it be the sun or Vray lights, has an intensity control called "MULTIPLIER". Your value in that box is obviously too high. Start by cutting it in half and see what that does then keep adjusting up or down.......and read and do the tutorials. Hi! thank you I would tyr again then Link to comment Share on other sites More sharing options...
sonybutarbutar Posted May 8, 2014 Author Share Posted May 8, 2014 Click this text for the links Ah I see thank you so much Link to comment Share on other sites More sharing options...
