Help Pls! Vray Install Error!
cornerofart
  • 8 months later...
Thanks but I find the solution, just delete files from the old version for v-ray 2 in this path:
C:\Users\[your computer name]\AppData\Local\Autodesk\3dsMax\2014 - 64bit\ENU
and re-installing the vray 3
Thanks for help.
Hey Man! I am struggling with the same issue. Can you please just tell which file needs to be deleted from the above folders before installing vray 3 ? I earlier had vray 3 installed ,but yesterday i got some error when 3ds max design 14 was not showing the side bars of vray 3 , then i uninstall vray 3 and tried to reinstall , but it's giving me continuous error .. Please help me brother :(
Vray has never been good at deleting and cleaning the old version files when upgrading to a new version. I've always had better luck uninstalling Vray manually through Windows control panel / programs and features. Uninstall it this way and then do a clean install and it should be good.
