Krisztian Gulyas Posted May 14, 2014 Share Posted May 14, 2014 (edited) I get the message that some maps are missing, though i deleted the object that had those maps on. After I deleted the object and opened Max again, this message appeared. Is there a way to get rid of it without ticking the "dont show this again"? Im using Max 2014 Thanks Edited May 14, 2014 by krisztiangulyas Link to comment Share on other sites More sharing options...
Scott Schroeder Posted May 14, 2014 Share Posted May 14, 2014 You still have the missing maps in your file. You also need to clear out the material in the editor, both slate and/or compact. Then that message will go away. It's best to solve the issue rather than just trying to hide the warning box. Link to comment Share on other sites More sharing options...
Krisztian Gulyas Posted May 14, 2014 Author Share Posted May 14, 2014 I cleared it already, but it wasn't enough. I checked the user paths/external files and there was a path I already deleted and it appeared again and again (i dont know why). When I deleted the folder which appeared there, the problem was solved. Link to comment Share on other sites More sharing options...
