Reversing Cars
Wokka
G'day,
I've animated several vehicles moving around an industrial project (aligned to a spline) but now the client wants to see the front-end loader reversing. I can't get the object to reverse, it (logically) follows the spline. Is there a easier trick to making it work without having to flip the whole object between two frames? I'm also trying to incorperate a great little Xpresso tag that rotates the wheels at the same time, it would be nice to have this effect but not a necessity.
Cheers
R9 + Advance Render
Wokka
Unless I'm misunderstanding you, you should be able to keyframe the position on the spline.
ie:
Frame 1=0%
Frame 30=100%
Frame 40=60%
This should cause an object to travel the length of a spline and the back up when it gets to the end. Add a little ramping in time curves and I think you're done.
Frosty,
The first example is great and simple but I would need to reverse on a different spline so the 2nd would be great, unfortunatley explorer can't find the file. Can you repost it?
Thanks again
Ace_Face,
Thanks for the idea, Xpresso is still a bit of voodoo for me but this might be a time to take a plunge. So much to learn, so little time.
Thanks
Cheers all
Wokka ( I suppose I'll have to wait for the sun to come up on your side of the world ;)
Ace_Face,
Using set driven keys is really simple. Really just run through that tutorial and you will see there are tons of applications where that can be useful.
