rakeshkumar3 Posted May 26, 2014 Share Posted May 26, 2014 Hi everyone, what is the best way to achieve the awesome pool water effect either with plugins or without. Please provide a link of your best water work and the process to achieve the same. looking forward for your support. Rakesh Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted May 26, 2014 Share Posted May 26, 2014 If you require geometry, you could try the houdini plugin. It has a free demo. If not, just make a shader that is reflective and refractive with some bump. Link to comment Share on other sites More sharing options...
rakeshkumar3 Posted May 26, 2014 Author Share Posted May 26, 2014 Great. And what about for animated sequence. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted May 26, 2014 Share Posted May 26, 2014 The waves can be animated in Houdini. You can also animate the bump on a shader/material if you use smoke/noise/wave/other procedural maps. Link to comment Share on other sites More sharing options...
Nic H Posted May 27, 2014 Share Posted May 27, 2014 i think houdini is total overkill for a 'simple pool water' try some nested noise maps and displacement on a plane or the faces of a box, that should get you pretty close Link to comment Share on other sites More sharing options...
Chris MacDonald Posted May 27, 2014 Share Posted May 27, 2014 Agreed, Houdini is a serious bit of kit just to do water in a pool. Noise maps can be animated, so work very well when used with displacement. Link to comment Share on other sites More sharing options...
John Dollus Posted May 27, 2014 Share Posted May 27, 2014 http://www.lysator.liu.se/~kand/caustics/CausticsGenerator_v1.4.zip I have used this for what seems to be a decade. It's pretty great and works for both stills and animated sequences. Don't overthink it. It's just a rendering. Link to comment Share on other sites More sharing options...
rakeshkumar3 Posted May 28, 2014 Author Share Posted May 28, 2014 Thanks @John. Will try the same. Link to comment Share on other sites More sharing options...
paneli Posted June 1, 2014 Share Posted June 1, 2014 http://www.lysator.liu.se/~kand/caustics/CausticsGenerator_v1.4.zip I have used this for what seems to be a decade. It's pretty great and works for both stills and animated sequences. Don't overthink it. It's just a rendering. SigerShaders have some great water mtls. Check it out here: http://www.sigershop.eu/index.php?option=com_content&view=article&id=6:v-ray-material-presets-pro-for-max&catid=31&Itemid=168 Link to comment Share on other sites More sharing options...
