Problem with viewport background image
paulhansen
I just had to find a place to upload my screenshots, that's why it took some time :)
Here's the original picture I want to render (Size: 1845x810 px)
This is the screenshot from viewport configuration
And this is the horrible result
//Paul
What is the purpose that you are doing sir ? is it for Match Moving ? then check Environment Setup Shortcut 8... Check it there.. if you are using VRay... then apply it as VRayHDRI Material in Materials list.. and apply it to Environment Setup.. wont work it on ? then send me again..
Ok sir.. Its a kind of Match moving.. then try to use with a plane or a half-cylinder.. Use the Matte Shadow Material.. give the image to the Diffuse of the Matte Shadow Material.. then i think that will be easy sir
Okay, I figured it out through a online tutorial.
What I had to do is, go to my Environment and Effects tab, choosing None and Bitmap and then the image I want to use. Then I had to open my Material Editor, drag and drop my image to one slot and choose instance instead of copy. Then I have to set Mapping to Screen on that slot.
That's it.
