fernando-1 Posted June 5, 2014 Share Posted June 5, 2014 (edited) I can't figure out why some surfaces are rendering with smudges in Vray (3dmax) see screenshot below. Please suggest a reason why. Thanks Edited June 5, 2014 by fernando-1 Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted June 5, 2014 Share Posted June 5, 2014 Its a 99% overlaping faces. So you may have 2 face one over other in one single object, or just 2 object, one over another, but placed at the very same position. This ussually happens when importing from ArchiCAD or Revit, sometimes... Link to comment Share on other sites More sharing options...
fernando-1 Posted June 5, 2014 Author Share Posted June 5, 2014 Zdravko, thanks that's what I thought myself too so I copied the surface and still renders the same smudges on the new surface. Link to comment Share on other sites More sharing options...
Ismael Posted June 5, 2014 Share Posted June 5, 2014 http://www.cg-blog.com/index.php/2012/10/22/splotches-vray.htm http://forums.cgarchitect.com/71909-v-ray-gi-hdri-splotches-blotches-spots.html Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 5, 2014 Share Posted June 5, 2014 If it is a geometry that you imported from other 3D or CAD software, check for double geometry fist, then check normal and smooth groups, sometimes un-weld vertex create strange behaviors like this ones. an easy way to check if it is GI or geometry problem is put a soft light in front of that area, is you have geometry problems it will still render like that, if it shows clean then you need to fix your GI, interpolation or number of sample, radios all that mabo jambo Link to comment Share on other sites More sharing options...
fernando-1 Posted June 6, 2014 Author Share Posted June 6, 2014 Yes thanks it was something to do with the geometry... I re modeled the same shape and the smudges went away. Link to comment Share on other sites More sharing options...
