Filling "the holes"?
Zdravko Barisic
I have surface like this
http://c2n.me/iilYA9
It is some kind of geo scaning of Earth, perhaps it is Dinaric Alps, but thats not the point.
This kind of ground, has a lot of holes, they are called "vrtache".
So, my question is:
Is it possible to fill these "holes" in some way? So, to have some nice clean surface?
To normalize it insome way?
So, I could use the surface for glue tool.
Thanks!
I was thinking how to cover new surface?
Yes, I am ready to loose details, for this kind they are not needed.
Or maybe, even, do it by "brute force", I mean by handcraft?
Place one plane over it, with 100x100 divides, and then pushing down, looking at existing shape?
It will be around 80-90% precise, but who cares, for this sort of use, it is not point, details.
If I do not find one-click solution, I will do by that, it will took some few hours, but these holes are impossible for roads.
EDIT:
OR to delete problematic polygones, and collapse the vertices, I tried on one hole, and it works fine.
There are not too many holes, only about 20-30, so it can be done in time.
Thanks to all!
BTW, this is the mountain
Edited by okmijun
Another method is to generate a heightmap from the existing surface, then paint out the 'holes' in Photoshop. That allows keeping the detail you want. Then use the fixed map to generate a new surface.
There's an expression "there's more than one way to skin a cat" though I am not sure it is literally true, nor do I really want to know for sure.
I guess you can also use smooth in the graphite modeling tools to manually smooth away the holes. I would still just use that script using a low res mesh and then turbo smooth it but that is only one way to skin the cat haha.
Sent from my SAMSUNG-SM-N900A using Tapatalk
