Shape merge/ Selecting the polies...
Zdravko Barisic
Ussually, when you use shape merge compound command, and then add edit poly modifier, and select F4, I got red marked selected polygones, which are made by the shape merging operation.
And thats cool, and that what we need very often.
BUT, sometimes, it does not happening!
Selecting those polygones, would take a months....
So, how to be safe it will select those poligones?
Hm, I found this
http://docs.autodesk.com/3DSMAX/15/ENU/MAXScript-Help/index.html?url=files/GUID-7894D0CE-D603-4ED9-895E-3A08FC5F393C.htm,topicNumber=d30e284836
.Output_Sub_Mesh_Selection Integer default: 0
Sets which selection level is output:
0- None (Outputs the full object.)
1- Vertex (Outputs the vertices defined by the spline of the shape.)
2- Edge (Outputs the edge of the merged shape.)
3- Face (Outputs the faces within the merged shape.)
to paste into command line, or what?
Thanks....but still selecting the vertices, only, even if I click on faces before picking the spline.
FINALLY:
The shape is "damaged", it works fine with shapes made in MAX, but imported, this time, not.
So, no solution, as I see, but to draw the shapes manually.
THANKS!
Edited by okmijun
