fernando-1 Posted June 15, 2014 Share Posted June 15, 2014 I've been having a real bad time trying to get from SketchUp to 3ds Max . I tried exporting to Dwg and Obj and also FBX but faces and layers don't import as predictable for some reason.. I'm must be missing something. I really would prefer using References > Manage Links. And I haven't had any luck with a couple of the free OBJ importers that are supposed to import with materials. Ideally I would like to construct my models in SketchUp and then import or reference as links to 3ds Max for final Vray materials and renders. Any advice? Thanks in advance... Link to comment Share on other sites More sharing options...
Josef Wienerroither Posted June 15, 2014 Share Posted June 15, 2014 3ds Max has a sketchup importer since i think Max 2014 ( or maby even Max 2013 ? not sure... ) It supports up to Sketchup 8 out from the Box. If you want to import Sketchup 2013/2014 files, apply the following trick i found out http://area.autodesk.com/blogs/maxstation/n229-importing-sketchup-2013-and-2014-files-in-3ds-max Link to comment Share on other sites More sharing options...
