jaypatel Posted June 18, 2014 Share Posted June 18, 2014 Hi all, Please find my project files https://www.wetransfer.com/downloads/10527ede7af204cda0ea9da8b79efb5820140616060742/0cc95d7714045fc6e5ba07e0523519d620140616060742/11e3bc i am having trouble with render Please have a look and give suggestions. Thanks. Link to comment Share on other sites More sharing options...
philipdutoit Posted June 18, 2014 Share Posted June 18, 2014 I can't download it at the moment...but can you maybe clarify what you are struggling with? It's not suppose to be that difficult. Link to comment Share on other sites More sharing options...
jaypatel Posted June 18, 2014 Author Share Posted June 18, 2014 Hi.. Thanks for reply. Rendered animation in flickering. Link to comment Share on other sites More sharing options...
hoseinasadi Posted June 29, 2014 Share Posted June 29, 2014 can you put a picture of your render and settings here? Link to comment Share on other sites More sharing options...
jaypatel Posted July 8, 2014 Author Share Posted July 8, 2014 Hi, Sorry for late reply..Please find the attacements>>http://we.tl/yUhLbijlHu Thanks, Jay. Link to comment Share on other sites More sharing options...
nitz3D Posted July 8, 2014 Share Posted July 8, 2014 Hey Jay... Here are some point u can try with.. Set your IRR to Custom and set the Min to -4 and Max to -1 and H Subdivisions to 30 and Int Samples to 28 Light cache Subdiv to 800, Sample Size to .015, Pre-Filter 32, Interp Samples to 5 and switch on "Use for glossy rays" and "Retrace" in DMC Sampler set your Adaptive Amount to 0.8, Noise thres to .005, Global Subdiv Multi to 2 and Min samples to 64 In Color Mapping set Type to Reinhard and Burn Value to 0.65 to 0.75. Try this out if something works out for you.. And one more thing for Animation rendering First Calculate the IRR with Incremental add to current Map and LC with Flythrough on every 10th or 20th Frames with Don't render final image on.. and then use it the saved calculations to render your final Image. Hope you got it.. If not you will need to reupload your project file as its not downloadable. Thanks Link to comment Share on other sites More sharing options...
