liorsturlesi Posted June 19, 2014 Share Posted June 19, 2014 Hi guys, I'm trying to make a short animation for a camera in 3DMax+vray, but have difficulties using the vray physical camera with path deform modifier so it can trace some short path i did. The camera is very hard to align correctly and i don't understand why. For the path i used a CV Curve line. Any advises will be appreciated. What is the best way to make a path for animation using the Vray Psychical Camera ?? Thanks, Lior Link to comment Share on other sites More sharing options...
John Dollus Posted June 19, 2014 Share Posted June 19, 2014 Best way is to not use a path. A very zen like response but it's true Link to comment Share on other sites More sharing options...
liorsturlesi Posted June 19, 2014 Author Share Posted June 19, 2014 But if you have a movement not in a straight line how can you adjust it ? Link to comment Share on other sites More sharing options...
shawnlim Posted June 20, 2014 Share Posted June 20, 2014 If you want a movement not in straight line u can adjust with Trajectories and Track View-Curve editor, here the sample .. Link to comment Share on other sites More sharing options...
shawnlim Posted June 20, 2014 Share Posted June 20, 2014 Link to comment Share on other sites More sharing options...
shawnlim Posted June 20, 2014 Share Posted June 20, 2014 But if you have a movement not in a straight line how can you adjust it ? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted June 20, 2014 Share Posted June 20, 2014 Keyframe it? Animation isn't my speciality. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted June 20, 2014 Share Posted June 20, 2014 The best way to control it is to create a dummy helper and link your vray camera (camera + target, don't forget the target) to that dummy. Then use the dummy with a path constraint to your animation spline. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted June 20, 2014 Share Posted June 20, 2014 In the meanwhile, post the screen of your issue. Link to comment Share on other sites More sharing options...
benjamincillo Posted November 21, 2014 Share Posted November 21, 2014 The best way to control it is to create a dummy helper and link your vray camera (camera + target, don't forget the target) to that dummy. Then use the dummy with a path constraint to your animation spline. Hello, If I try that dummy, camera, and target are not aligned, dummy can follow path, but camera is far away from dummy... any idea? thanks! Link to comment Share on other sites More sharing options...
Scott Schroeder Posted November 21, 2014 Share Posted November 21, 2014 Hello, If I try that dummy, camera, and target are not aligned, dummy can follow path, but camera is far away from dummy... any idea? thanks! Use the align tool the align the dummy to the camera. Link to comment Share on other sites More sharing options...
benjamincillo Posted November 21, 2014 Share Posted November 21, 2014 Use the align tool the align the dummy to the camera. Thanks, I have tried alignig camera and targe to dummy, but then when dummy is linked to path constraint, camera target is always tantgential to path. Standar cameras doesnt have such problem... Link to comment Share on other sites More sharing options...
