HDRI problem
essamelmenshawy
i have a question please, im working on some interior space , and this is the result i got from using "1433 Sun Blue Sky" , the scene is a bit dark and the HDRI is burning though
how can i make the scene brighter and fix the HDRI issue ?
... Also which should i be using HDRI file or EXR ?
i appreciate , thanks :)
Place Vraylights in the windows, set them invisible and tick the sky portal box.
Good luck :)
What are the settings on your hdri? Seems like inverse gamma is way low. Try to stay at at least .7 not any lower. I believe I read on Peter Guthrie's site that exrs have a higher dynamic range, that will get more dynamic lighting so I would go that route over hdri. Don't quote me on that go look through the blog it was a fairly recent entry I think.
i personally wouldnt suggest HDRI to light an interior with small windows. using default vray sun and sky would be more efficient in this scenario.
as for dome light value, it's best to set its value at 1 and change the camera setting instead, or bump up the HDRI intensity as you already have.
