fernando-1 Posted July 2, 2014 Share Posted July 2, 2014 Why do I get sometimes gray planes when I push/pull? Not be able to make them white again. See red arrows. Any suggestions welcomed. Thanks Link to comment Share on other sites More sharing options...
jensandersen Posted July 2, 2014 Share Posted July 2, 2014 Select all the "gray planes", right click one of them and choose: "Reverse Faces". It is the backside of the plane that is showing up "gray". Link to comment Share on other sites More sharing options...
Morne Erasmus Posted July 2, 2014 Share Posted July 2, 2014 Yes as Jens suggested. DO NOT apply a white material to those "gray" planes to MAKE them white because that doesnt solve the problem of the flipped face. If you have a cube for example and the one face is gray and the other are white, then it means that 1 face is the wrong way around (it's inside out and you need to reverse it like Jens mentioned) Link to comment Share on other sites More sharing options...
fernando-1 Posted July 3, 2014 Author Share Posted July 3, 2014 Jens Thank you Link to comment Share on other sites More sharing options...
Jason Matthews Posted July 9, 2014 Share Posted July 9, 2014 I will typically assign the backfaces a red color so that they are more easily seen. Then I reverse the faces. Some programs do not respond well to backfaces. Link to comment Share on other sites More sharing options...
