3DS Max 2014 - V-ray 3.0 Redner error
norbertbanyai
Hi All,
I have a problem that after the light cache process ( which looks just fine ) finishes, the render comes out all glitchy and black and white. It was working a few hours ago.
I've tried 3 different presets, nothing works.
I have restarted 3d max, tried new cameras, new settings... everything
Can someone help me with this one?
What Scott and Nitesh say is probably true. Most likely you have imported an object with materials vray doesnt like. Try to hide all your furniture (or other objects youve imported) and render again. If it works, unhide one model. Then keep going until the problem reappears. Then select the last object you unhid, open the material editor and click on "Get material from selected" and see if there are some materials that are not vray materials there. Then convert those materials to vray materials, and you should render just fine.
