Architectural glass opacity missing alpha channel
Ras
Hi again
I´ve run into a problem with my Architectural glass and alpha channels.
It seems that when i save my image and try to use the alpha channel to map my background into the picture the glass appears as a completely opaque object?!?
I don´t know how to work aroun this problem. I have no problem when using a standard material with for example 20% opacity but Architectural glass is so much nicer...
What to do?
  • 2 weeks later...
Hi Alexander
Thank you very much for your answer.
So let me see... I cannot use caustics then - I guess caustics are refraction dependent - right?
Also - I´ll loose the nice distortion that glass with thickness produces (like a prism) when IOR is 1, right?
What kind of glass do you recommend that I use then if I want to have alpha channel mapping available and still have realistic looking glass?
