tacianaviaud Posted July 17, 2014 Share Posted July 17, 2014 Hi I'm new at Vray and I have some issues with my glass material to reflect my hdri. Im not sure if its my material or the reflection/refraction environment the problem. It works on the sphere but not an a box. Here are my settings [ATTACH=CONFIG]51636[/ATTACH][ATTACH=CONFIG]51634[/ATTACH][ATTACH=CONFIG]51635[/ATTACH][ATTACH=CONFIG]51637[/ATTACH] Link to comment Share on other sites More sharing options...
Jon Berntsen Posted July 17, 2014 Share Posted July 17, 2014 Hi Alice, and welcome to the forum. I am not able to open your attachments. I don't know if it's because I am using an ipad or not. However, from what you say, I can imagine the reason being that your camera Z -> target is reflecting below the horizon line, and since most hdr images are black from horizon line and down, it will naturally only reflect the black lower part of the image. If this is the reason, your sphere will reflect the hdri from around the middle and up, and your box sides will reflect only the bottom if the map. If this is not true, I would like to see the images. Maybe you have a dropbox link or something? Link to comment Share on other sites More sharing options...
tacianaviaud Posted July 18, 2014 Author Share Posted July 18, 2014 It doesn't reflect at all :S. I have uploaded the images again Link to comment Share on other sites More sharing options...
Ismael Posted July 18, 2014 Share Posted July 18, 2014 (edited) http://www.neilblevins.com/cg_education/reflection_highlight/reflection_highlight.htm "When the light inside the room = the light falling on the objects that we desire to reflect, there will be no reflection. At night indoors with the lights turned on, you stand in front of your window whose other side faces the dark of night, you see your reflection as if the window was a mirror. At midday with bright daylight outside, your reflection (the one you had the previous night) would be gone." Make a glass panel 1/4 " by using a box primitive. Place next to the ball and see if it reflect. place at different angles too. Try a darker material on the cabinet momentarily. Oh, remove the material you have in the reflection slot and try. Edited July 18, 2014 by Ismael Add comment Link to comment Share on other sites More sharing options...
Jon Berntsen Posted July 18, 2014 Share Posted July 18, 2014 Make sure that the glass has thickness. Link to comment Share on other sites More sharing options...
