diference Multiframe incremental and Incremental add to current map
komyali
I am doing animation only camera is moving in interior, first want to do precalculations with
Irradiance map and light cache save it and than import them (from file) and render final frames. So I am confused between Multiframe incremental and Incremental add to current map, I dont see differences here? What is for what and in my case what is better to use?
_______________________________________________________________
Found answer on LINK
Q: Why did you choose Multiframe incremental over Incremental add to current map mode? What is the difference between the two that would cause you to choose one over the other? I ask because Ive never used Multiframe incremental and have always used the Incremental add to current map.
A: The only difference is that the Multiframe incremental mode will delete the map in memory at the start of the rendering. With the Incremental add mode, the current map is not deleted.
Edited by komyali
