nichlasudengaard Posted July 18, 2014 Share Posted July 18, 2014 I actually made this thread, only because of that I obviously can't post on my own thread:( --------------------------------------------------------------------------------------- Hi Again, I know that I can be pretty terisome... But I have done a quick try on the challenge, but why is the water reflecting the sand(plane)....?it looks pretty stupid:( http://s29.postimg.org/iemwbjsx3/reflect.jpg Thanks Regards, Nichlas ----------------------------------------------------------------------------------------------- Link to comment Share on other sites More sharing options...
nitz3D Posted July 19, 2014 Share Posted July 19, 2014 Hey Nichlas, I assume you using a plane object for the water surface. Try giving it a thickness with shell or making a new water object using a box. Reflection and Refraction works best with thickness in the object. Hope this will help you.. Link to comment Share on other sites More sharing options...
Ismael Posted July 20, 2014 Share Posted July 20, 2014 "But I have done a quick try on the challenge, but why is the water reflecting the sand(plane)....?it looks pretty stupid" Do you think that the water surface does not reflect? Not true. Google this: does the water surface reflect objects under it? http://fineartamerica.com/featured/u...-jt-lewis.html http://commons.wikimedia.org/wiki/Fi...tion,_Anna.jpg http://www.uwphotographyguide.com/un...hy-reflections http://www.phy.ntnu.edu.tw/ntnujava/...hp?topic=378.0 Google this: ocean floor water surface reflect http://www.123rf.com/photo_7899163_r...a-bareka-.html http://unitedstatesofpsychedelica.tu...ple-pattern-by http://flightrising.com/main.php?boa...id=984526&p=mb http://samisarkis.photoshelter.com/g...000eLceWQj787A Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted July 20, 2014 Share Posted July 20, 2014 These guys are right. It's going to happen. If you want to cheat this and make the water see through at the depth you are looking at it from, you will want to both reduce the Fresnel and Increase the Refrection. You can try ticking the reflect on backside box and use and HDRI which will make the plane equally as solid looking, but potentially give the water a different object to reflect. Maybe. Link to comment Share on other sites More sharing options...
Nic H Posted July 23, 2014 Share Posted July 23, 2014 check out snells window https://en.wikipedia.org/wiki/Snell's_window there is a thread on chaosgroup about this and rendering underwater scenes in vray Link to comment Share on other sites More sharing options...
Ismael Posted July 23, 2014 Share Posted July 23, 2014 nicnic said: check out snells window https://en.wikipedia.org/wiki/Snell's_window there is a thread on chaosgroup about this and rendering underwater scenes in vray Nice tip. I will be trying the 'bubble' tonight since I have been playing with a pool and the 3drender "Under The Boardwalk" challenge scene. Link to comment Share on other sites More sharing options...
Ismael Posted July 24, 2014 Share Posted July 24, 2014 First bubble try: Used a very cloudy sky map (free from Peter Guthrie) It rendered faster also, very nice start I think. Link to comment Share on other sites More sharing options...
