How to make TOOLBARS stay in position
barrymichael
Hi,
If you look at my attached image, I have had to create "separators" to space the tToolbars out. I find the Max toolbars confusing so I have created my own on the right side (for quicker access).
Is there a way to keep the Toolbars in place without using the separators?
  CoreyMBeaulieu said:
I'm not sure, but I would not recommend that you change this. Do what you want, but in a studio environment you often times end up working on a machine that is not your own and having to recreate your custom tool bars just to get started wounds like a right hassle.
I have the same problem in Sketchup. The toolbars don't stay in position. Everything piles to the left.
You could create a custom ribbon and that might be a much better way to consolidate things. Rather then use the toolbars, I tend to load things up in my quads.
At my previous place of employment, we stored our UI's on the network and had a script to load it all up if you moved machines. It was pretty dang sweet.
