paulostorch Posted July 29, 2014 Share Posted July 29, 2014 Hi guys, I have a quesiton regarding saving a picture after it renders in 3DS Max with Vray. After I render the scene and I'm pleased with the results, I then save the image as .png extension (and tried other extensions too), but when I check the saved image in my documents (or on Photoshop), It doesn't look anything like the finished render. I don't know what Im doing wrong. The image saved are washed out. I'm using 3DS Max 2014 with VRay 3.0. Some settings that i think it´s important to say here: - Gamma/LUT enable (2,2) affecting color selectors and material editor; - Image Sampler - Adaptive / Filter - VRayTriangleFilter; - Color mapping - Exponential with Gamma 2,2, Sub-pixel mapping and affect background checked; - Irradiance Map and Light Cache in Global Illumination I attached a printscreen of the problem, take a look. any suggestions, please? thank you. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted July 30, 2014 Share Posted July 30, 2014 When you do saving via SAVE AS dialog, down below on dialog, you have some option like "gamma 2.2.." Uncheck it, and it will be saved normal, or just check what option works best for you. Also, you can fix this by adding gamma 0.454 in Photoshop. Good luck! Link to comment Share on other sites More sharing options...
paulostorch Posted July 30, 2014 Author Share Posted July 30, 2014 Good! I will try this! Thank you! Link to comment Share on other sites More sharing options...
