VrayObjectSelect element problem
danielssan
Hello! I have a problem with VrayObjectSelect element in 3ds max and vray 3.0 . With the classic Frame buffer the passes for VrayObjectSelect element appear black, but they are saved, and with built in frame buffer from vray 3.0 the passes for VrayObjectSelect are visible in frame buffer but they don't save along with beauty pass even if i set the output path.Thank you!
Thanks for the reply! yes i did. As you can see in the image it renders all passes and channels in the frame buffer but it saves only what is in the forlder. in the elements list a have a zdepth and 3 VrayObjectSelect for each object in the scene.It only saves one of them.printscreen.jpg
