hassankhalid Posted August 20, 2014 Share Posted August 20, 2014 hellow please can anybody explain me how to fix this small small refelctions of light from empty map of ceiling... and this bright shadow from logo.. http://i60.tinypic.com/29zafc2.jpg[/img]"]http:// Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 20, 2014 Share Posted August 20, 2014 That's caused by your irradiance map settings. Forum search "splotches". Link to comment Share on other sites More sharing options...
hassankhalid Posted August 20, 2014 Author Share Posted August 20, 2014 That's caused by your irradiance map settings. Forum search "splotches". could u explain me here in shortkuts what todo.. exactly my friend Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 20, 2014 Share Posted August 20, 2014 Isolate the problem, create a global illumination render element to confirm that is where the source of the noise is from. Switch primary engine to brute force, because if you can't be bothered to forum search, I can't be bothered to explain the settings. Link to comment Share on other sites More sharing options...
hassankhalid Posted August 20, 2014 Author Share Posted August 20, 2014 Isolate the problem, create a global illumination render element to confirm that is where the source of the noise is from. Switch primary engine to brute force, because if you can't be bothered to forum search, I can't be bothered to explain the settings. i searched it my frnd no problem i will figure it out the problem..but there are lots of topics and explanations so thats why i was asking one specific answer Link to comment Share on other sites More sharing options...
guenther Malek Posted August 26, 2014 Share Posted August 26, 2014 Post the question again in the VRay-section of this forum; there are many specialist that can help you immediately Link to comment Share on other sites More sharing options...
