Francisco Penaloza Posted August 22, 2014 Share Posted August 22, 2014 Yep the title say it all. So I have this client send me a 3Ds model that was done in ArchiCAD, when I try to import to Max it come in a very small scale, no matter what units I setup in Max it always come very small and in a strange ratio. When I finally scale it to the right size, more or less a few mm, the viewport of max it shows really jacked up. Usually it show like this when the objects are too small or they are far from the origin, the size supposed to be fine, and I placed the building at 0,0,0 and still it look like Cra!#@p. any ideas? also any input of best practice to export from Archi CAD to Max. BTW the problem is not video card or drivers, any other models or even City scenes that I have show fine. Thank you Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted August 22, 2014 Share Posted August 22, 2014 Export with scale 1000mm and make sure the building is close to the drawing origo when exporting, that usually works for me. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 22, 2014 Author Share Posted August 22, 2014 Thanks for the answer, I will have to ask them to do that, sadly I don't have Archi CAD here and the owner is doing the export. Thanks again Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted August 22, 2014 Share Posted August 22, 2014 Try to turn ON viewport cliping, you'll get 2 small triangles, on the right side on viewport, along the yellow vetical line, so just move them up/ down, until you get proper viewport. Good luck! Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 22, 2014 Author Share Posted August 22, 2014 Thank for your input guys. View port clipping I did adjust that too, it was more noticeable before I scaled the model up. I told my client to re-export the model with Nicolai suggestion and I had to scale down the model now lol go figure, but now it is a t the right scale and the crazy viewport performance was fixed after applying Reset XForm modifier to the whole mesh. It was a suggestion from my co worker, and he explained that after enlarging the mesh is such drastically way, and re located close to zero coordinated, Max viewport get jacked up very easy. Applying Reset XForm modifier, seems to fixed the problem. Thanks you all for the help. Cheers \m/ Link to comment Share on other sites More sharing options...
