barrymichael Posted August 30, 2014 Share Posted August 30, 2014 When you load a VRmat in 3Ds Max and "assign" it the viewport objects goes grey and when you render in Vray you can see the material. But, you cannot "view shaded material in Viewport". It's blanked out. And it does not go RED as a result. Is there a way of being able to see the diffuse material in the viewport without having to render? Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted August 31, 2014 Share Posted August 31, 2014 Your vraymat, probably, has some kind of color correction map, so, thats way you do not see it. Anyway, post the screen of your mat editor, and check the "show textures" for viewport. Link to comment Share on other sites More sharing options...
