Tsiki Posted September 10, 2014 Share Posted September 10, 2014 I'm using max 2010 While working on my model, unexpected tiled floor turn to background color of the tiles ignoring the texture. Nothing of the following resolve my problem.: Creating new material. Using different texture JPG file I check the "Standard Display with maps" on material editor. Restart the PC. I also open my backup file and the same display problem. From the other hand, it appears in my rendered image. Any idea, please Link to comment Share on other sites More sharing options...
heni30 Posted September 10, 2014 Share Posted September 10, 2014 Did you press and disengage the "Display shaded material in viewport" button (light bulb icon at bottom of material samples) by mistake? Needs to be pressed in both the material and map windows. Link to comment Share on other sites More sharing options...
Tsiki Posted September 10, 2014 Author Share Posted September 10, 2014 Tnx. I'm not sure, but it might happened. Where is this button? I can't find it Link to comment Share on other sites More sharing options...
heni30 Posted September 10, 2014 Share Posted September 10, 2014 Button at bottom that says "Show map in viewport". Link to comment Share on other sites More sharing options...
Tsiki Posted September 11, 2014 Author Share Posted September 11, 2014 Thank you s much. It was tricky to find all places need to switch on the "Show Map in Viewport" because of several elements linked to create texture tiles. All the best, Link to comment Share on other sites More sharing options...
