Instance
komyali
Never ending question. Have same 9800 objects copied, I need 98 groups of 100 to be instanced? Found this script but like I see in video everything would be instanced. Does anybody know good script for this, I am in a hurry so I dont have time to research scriptspot and test every script.
tnx
Um... your script is called the Select Tool. Select manually your 100 objects, make a group and instance it to where the other objects are; Hide your groups and then delete the leftover.
If you are talking about 98 "objects" that are actually made from 100 pieces, then make your 98 groups that aren't instanced, select one as your Instance, change the layer and use Max's internal Clone-Align Tool.
