thespokesman Posted November 1, 2004 Share Posted November 1, 2004 trying to render a space using musuem lighting or spotlights using max 6 i need help im going to use radiosity how can i make a space as real as possible wood floor, metal panel walls acoustic ceiling (grid) Link to comment Share on other sites More sharing options...
Devin Johnston Posted November 1, 2004 Share Posted November 1, 2004 It's hard to say how you can make an image more realistic without something to look at. Generally I would say that with Radiosity using IES lights for interiors is a good idea, and the specks for those should be easily supplied by the manufacturer. Once you get your lighting set up then start working on the materials, if they aren't any good then it won't matter how good your lighting is. I see you’re in Houston, where do you work? Link to comment Share on other sites More sharing options...
