Graphite Posted September 30, 2014 Share Posted September 30, 2014 Hey All, I was trying to create shapes from shadow casts in Vray, but to no avail. (IE. placing a flat tree shaped object next to a light to cast a tree shaped shadow on a wall.) Is this even possible? Or would I be better off trying another method? If so, what would be the best way to go about this? Regards, Nolan Link to comment Share on other sites More sharing options...
John Dollus Posted September 30, 2014 Share Posted September 30, 2014 Sounds like you are looking for a gobo effect? Use a standard light, toss the image in the projector map slot and change the shadows to vrayshadows. Is that what you are after? Link to comment Share on other sites More sharing options...
Graphite Posted September 30, 2014 Author Share Posted September 30, 2014 Thanks John, That was actually going to be my next option. The Image attached is pretty much what i'm trying to do. Link to comment Share on other sites More sharing options...
carloscristerna Posted September 30, 2014 Share Posted September 30, 2014 It all depends on the size of you vray light, here is a sample of a small 1cm light projecting on a 10mx10m back. If you think about it you need to replicate the light source, a light bulb even a modern one is a very small light source, the bigger you make it the less intense it needs to be but the more diffuse it will be. the projection method works also and gives you some more control. cheers. Link to comment Share on other sites More sharing options...
John Dollus Posted October 1, 2014 Share Posted October 1, 2014 Carlos, are you going to be in Dallas later this month for the architectural illustration conference? It would be great to catch up since San Fran. Link to comment Share on other sites More sharing options...
carloscristerna Posted October 1, 2014 Share Posted October 1, 2014 Hey John, YES! we will be there, Ryan, Hao and I will be there. we are looking forward to it! Link to comment Share on other sites More sharing options...
