file size going nuts???
blaz
Hi,
I have a simple scene for max 6 that starting about 7Mb and i am using final render for the rendering, and after a while the autosave become so heavy after i realize that the file turn to 20Mb, i didn't merge anything heavy inside,
so, i trying to delete some of the object inside and the file size still remain even i delete them all.
so i merge back one of the item that i deleted, and it makes my file size even double from 20 mb to 40 mb.
attached is the information from my file summary info.
any body there that experiance this, please give me advice how to solve this, because now it grow to 70mb already.
thanks in advance.
W
hi quizzy,
it works when i used the "compress on save" i am not using the other trick because i don't have any xref in my file.
my question is, if i enable the "compress on save" all the time, without disable it, would that make my file all right? because when i diasble it turn back to huge size
hi quizzy,
Hi blaz,
It doesn't matter whether you're using xrefs or not. Try the xref/gc method. It works.
