Zdravko Barisic Posted October 10, 2014 Share Posted October 10, 2014 (edited) Please look at these images: http://www.pillmaharam.com/projects/images/residential/Enlargements/east%20side-Studio%202.jpg http://www.nss-exteriors.com/images/work_41707_013.1.jpg Its about metal sheet walls with small pyramidal section. My question is: HOW would you make these walls, if they are crowded with openings? By polymodeling or using some displacement maps? Displacement maps can cause black holes in the end of faces? Edited October 10, 2014 by okmijun Link to comment Share on other sites More sharing options...
Justin Hunt Posted October 11, 2014 Share Posted October 11, 2014 Depending on how much cladding is needed I tend to polymodel, although can make the scene poly heavy. For the opening just cut the edges and delete the opening. Displacement is lighter on the scene but can be heavy on the rendering. Some times the edges can muck up. You may have to uv-unwrap if you have complicated edges I recently did this one https://www.behance.net/gallery/18933709/Civic-Center-Refurbishment which was polly modeled. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted October 11, 2014 Author Share Posted October 11, 2014 Yeah, I probably will end up with poly modeling. Thanks! Link to comment Share on other sites More sharing options...
