Zdravko Barisic Posted October 10, 2014 Share Posted October 10, 2014 Please look at these images: http://www.pillmaharam.com/projects/...Studio%202.jpg http://www.nss-exteriors.com/images/...1707_013.1.jpg Its about metal sheet walls with small pyramidal section. My question is: HOW would you make these walls, if they are crowded with openings? By polymodeling or using some displacement maps? Displacement maps can cause black holes in the end of faces? Link to comment Share on other sites More sharing options...
heni30 Posted October 10, 2014 Share Posted October 10, 2014 seems like jpgs aren't showing up..........as least for me Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted October 11, 2014 Author Share Posted October 11, 2014 Try this now, the above links really does not work, do not know why. http://www.pillmaharam.com/projects/images/residential/Enlargements/east%20side-Studio%202.jpg http://www.nss-exteriors.com/images/work_41707_013.1.jpg Link to comment Share on other sites More sharing options...
heni30 Posted October 11, 2014 Share Posted October 11, 2014 I would make one big sheet and cut window holes in it. Seems simple enough geometry to not cause any problems. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 11, 2014 Share Posted October 11, 2014 I did this recently. Definitely worked best to make a whole wall and then just boolean out the openings all at once. For close up this worked best, but mid to far distances I would recommend exaggerating the depth a bit. The lighting didn't pronounce the corrugation well in my image. Also, especially on close ups, the material is going to want to have a higher subdiv and blurry reflection than an optimal render time would like. For best results I suggest just eat the time and get a clean render. This amount of detail can be very noisy Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted October 11, 2014 Author Share Posted October 11, 2014 Yeah, I will ended by booleaing...thanks! Link to comment Share on other sites More sharing options...
