philvanderloo Posted October 12, 2014 Share Posted October 12, 2014 I'm messing around with some glass materials on different objects and wondering why these objects aren't showing in shaded view unless they are selected. They show up fine in wireframe but disappear when view is switched to shaded. All 3 have a slightly different material applied so I doubt it's a material issue? Link to comment Share on other sites More sharing options...
heni30 Posted October 12, 2014 Share Posted October 12, 2014 It's because the glass materials are transparent. You can create a test material on an object and move the refract slider and watch it disappear. You can use edged faces to see where things are. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted October 13, 2014 Share Posted October 13, 2014 It's because your material has 100% refraction. Watch what happens if you take it down to 70%. Link to comment Share on other sites More sharing options...
Tommy L Posted October 14, 2014 Share Posted October 14, 2014 You can disable viewport transparency in the viewport configs if you like. Link to comment Share on other sites More sharing options...
