charlesnasr Posted October 12, 2014 Share Posted October 12, 2014 Hello guys, so Im using vray dirt and for some reason It's behaving very weird, It's offsetting from the corners.. I tried to switch materials and created a new material and it didn't help... Thanks in advance. Link to comment Share on other sites More sharing options...
simonm Posted October 13, 2014 Share Posted October 13, 2014 check to see if you have reverse faces... that can cause some artifacts Link to comment Share on other sites More sharing options...
jayeshmane Posted October 13, 2014 Share Posted October 13, 2014 you may also check object may intersect each other Link to comment Share on other sites More sharing options...
aminbakht Posted October 21, 2014 Share Posted October 21, 2014 seems like you have flipped normals on and they are interacting with some objects inside that are intersecting. Link to comment Share on other sites More sharing options...
charlesnasr Posted October 21, 2014 Author Share Posted October 21, 2014 Thanks guys for the help it turned out as Jay said it's working perfectly now after I deleted the faces. Link to comment Share on other sites More sharing options...
