wenhaotan Posted October 19, 2014 Share Posted October 19, 2014 Hello everyone, I have been facing this issue. I've isolated it down to a single area light. So long as it glances around the surface. This happens. I've gone through all the settings, and I am using a linear workflow. The below did not help - - increasing sample counts on lights subdiv value does not work - light cut off threshold does not work - not caused by rec tex - not caused by rec tex resolution - Problem isolated to reflection specifically What is causing this? Any ideas? Thank you. Link to comment Share on other sites More sharing options...
