bugnariutudor Posted October 20, 2014 Share Posted October 20, 2014 The render doesnt actually STOP...the time goes by but nothing more happens...it stays at that last bucket.everything was going good for the test renders..but when I bumped up the settings this thing came my way.I m using IR map with light cache. I hope u guys understand what my problem is,I ll post a print screen so u can get the idea.If u need more details from me please say so.thank u very much Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 20, 2014 Share Posted October 20, 2014 What are you Irradiance settings? Link to comment Share on other sites More sharing options...
bugnariutudor Posted October 20, 2014 Author Share Posted October 20, 2014 hello..thanks for the fast reply...I ll post an image with my render settings Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 20, 2014 Share Posted October 20, 2014 Your settings seem pretty normal to me. I'd probably use a default of medium and then go custom for a min/max of -5/-2, otherwise I wouldn't suggest anything different. What happens when you render a half size test? The only time I've run into a similar problem was with with dense vegetation and the irradiance map was having trouble solving the detail. It always worked at a lower res so I wound up pre-calculating an IRR at a lower res and then using it on the full size image. Link to comment Share on other sites More sharing options...
bugnariutudor Posted October 20, 2014 Author Share Posted October 20, 2014 so what you're saying is that I should lower the resolution and render just to see if IRR works...and if it does I can go back to my original size with the same IRR settings? sorry if I don t understand I m a little newbie. P.S forgot to say that I increased the subdivis of the grass reflection...from 8 to 32...don t know if it has anything to do with it. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 20, 2014 Share Posted October 20, 2014 I would render a test at a smaller size. If that works then you will need to look at reducing your IRR settings or consider rendering a pre-calculated pass at the smaller size and then using it as your IRR on the full res. The more you up your subdivs, the slower it will render, but until you run out of memory, it shouldn't effect much. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted October 20, 2014 Share Posted October 20, 2014 If you are using Forest Pro and Vray 3, it is a known issue with an older version that it will hang the render on the last imap bucket. It has been solved for some time now. Make sure you are completely updated on both softwares. http://forum.itoosoft.com/index.php?topic=2165.msg8024#msg8024 Link to comment Share on other sites More sharing options...
bugnariutudor Posted October 20, 2014 Author Share Posted October 20, 2014 I am using Multiscatter....and 3ds max 2014 vray 3.003,I don think there's a newer version of vray for 2014... Link to comment Share on other sites More sharing options...
Scott Schroeder Posted October 20, 2014 Share Posted October 20, 2014 Yeah there have been 2 updates to Vray from your version. You are at Vray 3.00.03, the actual working Vray version is 3.00.07. Link to comment Share on other sites More sharing options...
bugnariutudor Posted October 20, 2014 Author Share Posted October 20, 2014 I can t seem to find a newer version for max 2014. at least not a cracked one...and I won t pay 800 euros for it,as I m only doing projects for learning purposes(I have the student version).If someone has a download link I will appreciate it thank you. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 21, 2014 Share Posted October 21, 2014 I can t seem to find a newer version for max 2014. at least not a cracked one...and I won t pay 800 euros for it,as I m only doing projects for learning purposes(I have the student version).If someone has a download link I will appreciate it thank you. No one here will provide you with this. You should know to never ask. It is illegal and immoral. Cost is something we all deal with and as a this is a professional forum, we all are creating commercial works that require commercial licenses. Those who steal not only reduce Chaos Groups ability to better their product, they also begin to affect the market as a whole. Not having the same overhead as an upstanding individual or studio puts you in at an unfair advantage and the windows for the opportunity of receiving help here will slam shut. Link to comment Share on other sites More sharing options...
Fr3Drick Law Olmstead Posted October 21, 2014 Share Posted October 21, 2014 (edited) I can t seem to find a newer version for max 2014. at least not a cracked one...and I won t pay 800 euros for it,as I m only doing projects for learning purposes(I have the student version).If someone has a download link I will appreciate it thank you. Chaos Group offers academic licenses for students V-Ray Academic license – 74 EUR/ 103 USD/ 64 GBP per license http://www.chaosgroup.com/en/2/vray_academic.html As a student you are eligible to purchase an Academic license at comparable low cost to develop and practice your skills and you will be able to receive all the support you need directly from Chaos Group. The license agreement prohibits you from producing any commercial work which you say you are not using it for that anyway. Edited October 21, 2014 by Fr3Drick Law Olmstead Link to comment Share on other sites More sharing options...
A3DISENYOS Posted November 2, 2014 Share Posted November 2, 2014 A couple of weeks I tried Vray 3.003, and the best thing I see in the ago, is starting the new renders, you can choose from: Custon, exterior, interior, and another 2 more. Try to give, which you see fit, having prepared the Gamma 2.0, Good key render, and is impressive at first, it seems that now we must not walk with both setins, Vray, now this new tool brings I think, very good Setins. Julián García Link to comment Share on other sites More sharing options...
jayeshmane Posted November 3, 2014 Share Posted November 3, 2014 @Bugnariu kindly check may be not enough space in your c: drive because same thing happen to me and also set default memory to dynamic in vray setting section http://renderstuff.com/best-vray-settings-raycasting-cg-tutorial/ Link to comment Share on other sites More sharing options...
