3dmax importing dwg format : unable to attach this file; file maybe missing or currpt
winlyc
Hi,
This is a very ounable to import.jpgdd problem I am facing with. I can't import any *dwg* format; either in 2D or 3D format which I occasionally would have to import from many given 3d files from my architects and clients. When its fresh and fine (3dmax software), importing would be a breeze, but once this error pops up, its a death verdict that "from there on..." I can no longer import anymore dwg format working files.
I will always have to reformat the pc and it will work just fine after an overhaul formatting. Is there any solution to fix this problem;without having to reformat every now and then? The quirky part is that it occurs only on my pc and my other colleagues pc would work just fine, importing from the same file, same setting,same 3dmax format, same units>>basically everything's same, theirs works just fine but mine, the same error would pop up.They too are baffled to why this only occurs on my pc and at home. Is it a bug embedded somewhere? Please help me~~
