agussalimzulfan Posted October 27, 2014 Share Posted October 27, 2014 hi, i'm new to 3ds max, i have a problem on user machine. 2 machine with the same spec intel® Xeon® CPU E5-1620 @ 3.60GHZ Qaudro K2000 16 GB RAM 2x 1TB HDD and the same file. when rendering on 1 machine the cpu usage is 100% but the other is between 20-60%, all are default setting. anyone can help me with this issue. Thanks Link to comment Share on other sites More sharing options...
jasonstewart Posted October 30, 2014 Share Posted October 30, 2014 Have you run a stress test on the offending computer to rule out any issues with the system? Try running Prime 95 for at least an hour to make sure that it is stable. Link to comment Share on other sites More sharing options...
heni30 Posted October 30, 2014 Share Posted October 30, 2014 Have you tried change performance/power settings in Windows System? What is the Windows Experience Index for CPU for the slower machine? Link to comment Share on other sites More sharing options...
agussalimzulfan Posted October 31, 2014 Author Share Posted October 31, 2014 jason stewart: yep already stress test and the system is running fine. george sandoval : will try it. Link to comment Share on other sites More sharing options...
heni30 Posted October 31, 2014 Share Posted October 31, 2014 I went to System - Performance Info and tools - You'll see your CPU score there (should be 7.x) - Adjust powers settings - Balanced - Change plan settings - Change advanced power settings - Then at the top I chose High Performance. My 4770k was rendering 30% slower than my i7 920. Now it's rendering twice as fast. Link to comment Share on other sites More sharing options...
