adomalindanick Posted October 31, 2014 Share Posted October 31, 2014 why do i get this error when i open a max file pls help Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 31, 2014 Share Posted October 31, 2014 Everytime? My best guess is that at some point, you loaded in a library that contains a material using this plugin..... I see it a lot with libraries that use a Multi-Scatter Map that I don't have. In your material editor (Slate) i would look for loaded libraries that don't pertain to your render engine or Naive Max libraries. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted October 31, 2014 Share Posted October 31, 2014 Do you have the Vray render engine installed? If not, that is why you are getting that error. Ignore it, replace all materials with standard mats and delete any VrayDisplacement modifier on geometies (my guess would be this is on a tire if it is a car). Also, clear all material libraries, both standard AND slate. Save, close, and re-open. The error should go away. Link to comment Share on other sites More sharing options...
Mamoon Bestani Posted November 2, 2014 Share Posted November 2, 2014 you are opening file which have model with Vray DisplacementMod Modifier, to see the affect you should have vray installed on your system . __________________________ http://www.dubai3dmax.com/ Link to comment Share on other sites More sharing options...
adomalindanick Posted November 5, 2014 Author Share Posted November 5, 2014 thnks guys Link to comment Share on other sites More sharing options...
nileshbhagwat Posted November 6, 2014 Share Posted November 6, 2014 some plugins are missing Link to comment Share on other sites More sharing options...
