objects end up flying everywhere when I unlink them?
Rich O
So I've imported a dwg from Revit and when I go to move certain bits of geometry, they pull others (instances of some sort) with them. Tried unlinking them, however that just messes everything up and sends the instances flying all over the scene basically.
It's a bit hard to explain in words so I've exported some of the offending objects and attached a small scene to demonstrate crazy geometry test.zip
Tried, unlinking, tried reset xform, nothing works. Any help would be great!
  • 3 months later...
  martinhoura said:
run this script
for o in objects do (
o.controller=prs()
if classof o.parent == LinkComposite do o.parent = undefined
for o in objects where classof o == LinkComposite do delete o
that doesn't seem to do anything, only gives me an error. Is the syntax correct?
