Acad vertices spiking.
heni30
I received these 2D acad files of an interior that have vertices going up and down in 3d - like about 500 feet.
It's a pain just looking at it and when I do "zoom extents" my building is small because it includes the rogue vertices. Is there any command in acad that would flatten everything out like it's supposed to be?
Edited by heni30
Hey, thanks Zdravko. Flatten doesn't work.
And the move commands might have gotten rid of the depth problem but when it comes
into max it is so far in outer space that max can't find it. (I tried changing the absolute world coordinates and moving it with type-in values
but max just keeps the values of 8333333'4" - no change.
Max refuses to have anything to do with it. (small store floor plan is 1600 miles away from 0,0,0,.
Edited by heni30
@ Can also go to front view for example. select all - properties / start y=0 and end y=0
Elevation=0
To all elements possible.
I tried doing that but when selecting all the lines the option to change start and end values was not available. Selecting some of them gave that option. But that means I'd have to hunt down the lines that were causing the problem.
@ why don't you move it to 0,0,0, in acad?
Yep - but at that point (no pun intended) I had Googled the problem and saw that Flatten wasn't working because Express Tools was missing.
Edited by heni30
  • 4 weeks later...
