alex3d Posted November 3, 2004 Share Posted November 3, 2004 i have 2 dual xeon workstations, when i'm doing renders in final render is beatiful to see 8 procesors rendering a single frame but, is faster use hyperthreading? i can go to the bios and disconect hyperthreading to compare but i dont like hardware experiments with expencive technology. lol Link to comment Share on other sites More sharing options...
Tiny Piney Posted November 3, 2004 Share Posted November 3, 2004 Good Question. I would like to know as well. I far as I understand hyperthread use the unuse processing power that most programs leave behind. But does happen with a huge number crunching program like rendering? Link to comment Share on other sites More sharing options...
Tim Nelson Posted November 3, 2004 Share Posted November 3, 2004 There's been a lot of discussion on this at the Vray forums. Its been generally noted that enabline HT will give you a significant performance boost. You should give it a try! I honestly am pretty confident that you won't break anything by turning it off & on. So in general, I think all bucket renderers really take advantage of HT, but not sure about other types of programs. Link to comment Share on other sites More sharing options...
rivoli Posted November 4, 2004 Share Posted November 4, 2004 as timmatron pointed out HT should give you a more or less significant increase in rendering performance. anyway, i'd suggest you to test a scene with and without HT enabled to draw your own conclusions. don't worry about turning it on and off, it's not a big deal and it won't cause any trouble to your system. you may also want to check this link to get a better insight into what HT actually is: http://www.2cpu.com/articles/42_1.html hope it helps. Link to comment Share on other sites More sharing options...
STRAT Posted November 4, 2004 Share Posted November 4, 2004 HT boosts rendering speeds by up to an extra 25% in cinema4d Link to comment Share on other sites More sharing options...
Hazdaz Posted November 25, 2004 Share Posted November 25, 2004 I believed that HT would speed up rendering too... BUT then someone pointed out that HT gives you a speed boost by using unused cycles of the chip... BUT what you guys are forgetting that when rendering, the chip is usually at 100% usage already, so there really aren't any EXTRA cycles to use. Becuase of that I have read that when rendering its not much of a speed boost. One of these days I will actually TRY it, and while it is fun to see 4 buckets flying around (I have a dual XEON), I have my doubts that its really that much faster. Link to comment Share on other sites More sharing options...
