alejandrofernandez Posted November 12, 2014 Share Posted November 12, 2014 Hi, I´m rendering this kitchen and the lights coming from the window are too bright. How can I make them less bright, Im not using vray sun, just vraylight. Here´s the image with the problem. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted November 12, 2014 Share Posted November 12, 2014 Turn the multiplier of the light down? Link to comment Share on other sites More sharing options...
alejandrofernandez Posted November 12, 2014 Author Share Posted November 12, 2014 I don´t have any lights outside, just inside. Im using vraysky. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted November 12, 2014 Share Posted November 12, 2014 I see, A couple of things. First, you should set you exposure to the sky that is outside and then setup the intensities of the interior lights. or You can go to your VraySky Map, tick "Specify Sun Node." This will activate the properties below which will allow you to tell the sky that you want a lower intensity Sun. Link to comment Share on other sites More sharing options...
alejandrofernandez Posted November 14, 2014 Author Share Posted November 14, 2014 That helped! Thanks! Link to comment Share on other sites More sharing options...
