How rig a crane so the crane wires extend as the hook is lowered
alastairerrett
Hi Everyone
I have a crane I'm trying to rig that I need some help with. I need to rig the crane so that as I lower the hook of the crane the wires attached to the hook extend. I tried doing it with a LinkedXform but although I got the wires to extend as I lower the hook, ass soon as I rotated the boom of the crane the wires went off in a strange direction.
Does anyone know how to do this?
Thanks
Have you tried a LinedXform modifier? If you select a vert, place a point help on it, and then add a linked xform while the vert remains selected, you can animate the helper.
Hi, Yeah I tried a linked xform and I could get it to extend the crane wires but then when I move the boom of the crane the wires break off from the crane. I think it's to do with the pivot point but I can't sort it at the moment and I don't see why adding the linked xform would change where it pivots from when it was working fine before adding the linked xform
Hi Guys,
I've created a very simple crane rig in Max so you can all see the problem I'm having more clearly. As the crane boom is rotated down or the base rotated the linked xform stops working and the wires go off at an odd angle.
Any help would be greatly appreciated. Thanks for the help so far
Mechanical Linking-Crane Mockup.zip
Give this a try. You were almost there. The only two objects you now need to animate are the parts coloured red, the pulley and the boom pivot
[ATTACH]52318[/ATTACH]
Hi thanks George that looks great. I've now managed to do this using two hose objects 'bound to object pivots' for the crane wires. I'm going to have a go at reproducing yours as well so I have two methods and I'll see which one works best and is easiest to setup.
