alastairerrett Posted November 14, 2014 Share Posted November 14, 2014 Hi, I have an object I'm trying to link to a helper object. The pivot points of both objects are aligned but when I try to link the two objects suddenly one of the moves off to the side. Does any one know why this happens and how to fix it? Thanks Link to comment Share on other sites More sharing options...
alastairerrett Posted November 17, 2014 Author Share Posted November 17, 2014 George said: Possible solutions: Try going to Hierarchy tab > Pivot and click Reset Pivot button. If you have added a Linked XForm modifier try unticking the Back Transform box from the modifier parameters. Hi George, thanks for that, resetting the pivot point sorted the problem. Link to comment Share on other sites More sharing options...
nawazali Posted November 18, 2014 Share Posted November 18, 2014 Hi guys, Would you please help me to figure out what is wrong with my material settings.... You can see that on the left hand the light is OK, meaning, the light passes through the kind of light bulb (basically sphere #1), and after that the light passes through just a round glass shape (sphere #2). But on the right hand i start getting a problem as soon as i add another glass sphere (sphere #3). Nothing is changed, i have only added 1 additional glass sphere. ________________ Nawaz Link to comment Share on other sites More sharing options...
