alejandrofernandez Posted November 17, 2014 Share Posted November 17, 2014 Hi, Need help! What lights will give me a more realistic result...and also what light should be used where, I mean dome lights works better for?? and plane light works better for?? Should I use both? Thank you Link to comment Share on other sites More sharing options...
Ismael Posted November 18, 2014 Share Posted November 18, 2014 :phttp://www.cgchannel.com/2012/10/10-tips-for-lighting-and-look-development/ http://3d.about.com/od/Creating-3D-The-CG-Pipeline/tp/8-Tips-To-Increase-Realism-In-Your-Renders.htm http://www.hdrlightstudio.com/blog/image-based-lighting/a-guide-to-cg-lighting/ http://www.andrew-whitehurst.net/fx_light.html http://cgi.tutsplus.com/tutorials/achieving-realistic-results-with-3ds-max-v-ray-an-interior-lighting-and-rendering-overview--cg-13499 http://www.diva-portal.org/smash/get/diva2:119709/FULLTEXT01.pdf Link to comment Share on other sites More sharing options...
alejandrofernandez Posted November 19, 2014 Author Share Posted November 19, 2014 :phttp://www.cgchannel.com/2012/10/10-tips-for-lighting-and-look-development/ http://3d.about.com/od/Creating-3D-The-CG-Pipeline/tp/8-Tips-To-Increase-Realism-In-Your-Renders.htm http://www.hdrlightstudio.com/blog/image-based-lighting/a-guide-to-cg-lighting/ http://www.andrew-whitehurst.net/fx_light.html http://cgi.tutsplus.com/tutorials/achieving-realistic-results-with-3ds-max-v-ray-an-interior-lighting-and-rendering-overview--cg-13499 http://www.diva-portal.org/smash/get/diva2:119709/FULLTEXT01.pdf Thankyou this was ver helpful Link to comment Share on other sites More sharing options...
Amen Posted November 24, 2014 Share Posted November 24, 2014 We usually only use a HDRI dome light to light the exterior of a scene. Then we add all the lights that would really be in the room. Mostly IES lights for all spotlight type lights and and vray lights for area type lights. This can amount to quite a lot of lights but it looks good, but renders a "little" longer. Link to comment Share on other sites More sharing options...
