clydelim Posted November 18, 2014 Share Posted November 18, 2014 Hi guys, I am learning 3dmax vray just yesterday and I faced some problem. I have attached 2 files which one with walls and one without wall. As you can see, the HDRi environmental map are very narrow in the middle, I also notice that there is a white patch with opacity in the upper environment. How do I actually solve this issue? On the other side, I place my vray light, but there is no sun light to the interior ground, is there any technique to make it happen? I have attach the file for your reference too. Thank you so much from a vray noobie Link to comment Share on other sites More sharing options...
clydelim Posted November 18, 2014 Author Share Posted November 18, 2014 I have solve the environmental issue, which is modifying some of the dome light setting. But how do I allow sunlight into my interior? I have place a vray light on my window. Without the glass, the sun light is able to pass through but unabled if I have a glass in between. Link to comment Share on other sites More sharing options...
clydelim Posted November 18, 2014 Author Share Posted November 18, 2014 Problem solved... Link to comment Share on other sites More sharing options...
elipan Posted November 20, 2014 Share Posted November 20, 2014 clydelim said: Problem solved... How about posting your solution? Link to comment Share on other sites More sharing options...
